cat or test pipe?
Old Oct 11, 2002 | 11:44 AM
v4lu3s's Avatar
v4lu3s
a test pipe doesnt offer any noticeable performance gain over a good high flow cat.
Old Oct 15, 2002 | 07:50 PM
knightridergs-r's Avatar
knightridergs-r
Originally posted by lttletimmy
It'll be way louder, and if you use a test pipe the gains will actually be pretty big. Think about it, larger diameter tubing plus there won't be 2 large posts blocking the flow, you'd notice quite a sizable difference. But i still don't condone it, I would go with the high flow cat. It won't be as loud, you'll still gain a little bit (but not much) and it'll be legal
actually there wont be HUGE gains, maybe 1or 2 hp depending your setup, a high flow cat with proper size at the flanges to match your exhaust setup wont restrict the exhaust flow threw the cat, that is a fact. look into carsound hi flow cats, dyno has proven an additional 1hp at the wheels over a test pipe. dyno testing was done on an integra gs-r with a full smsp exhaust set up
Old Oct 16, 2002 | 09:42 AM
cdowney00's Avatar
cdowney00
...how the hell do you get more horsepower with added restriction? :eh: Not saying your wrong just seems you get all the back pressure you need from the headers and the rest of the pipe and any extra beyond what your engine needs is wasted energy. Am I wrong in that assumption?
Old Oct 16, 2002 | 11:53 AM
knightridergs-r
the reason why stock cats are restrictive is because the flanges on both ends are usually smaller because they were made to fit a stock exhaust, for example cat flange size on stock cat on a car say an integra the size at the flange will most likely be around 1.75' and when you have that stock cat on an exhaust and header with say 2.5' tubing and 2.5's at the flanges on both header and exhaust then you are going to have a bottle neck effect which slows down the flow velocity which creates restriction which leads to backpresure which is bad. the 3 parts to the cat are the reduction catalyst, oxidation catalyst, and the ceramin honeycomb catalyst which are all free flowing especially in hi flow cat converters. the only reason why you get gains from a test pipe is because the tubing and flanges are bigger to match your set up. if you buy a hi flow cat such as carsound they come with the proper size flanges for your setup hence you gain more power and dont pollute the air we breath.
