spark plugs
Old Apr 8, 2007 | 01:20 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
If Vega did the ECU, it was done with CROME.
Old Apr 8, 2007 | 06:46 PM
ls_on_boost's Avatar
ls_on_boost
ls_on_boost
i'm trying to put a pic so you can tell me if it crome or eprom it's black and says sst on it
Old Apr 8, 2007 | 09:45 PM
dubcac's Avatar
dubcac
I
Regardless, if his plug electrodes are white, he's running lean. If he already has Crome, he needs a retune.
Old Apr 29, 2007 | 05:11 AM
ls_on_boost
ls_on_boost
wide band is hooked up cruiseing my wideband show lean anywhere from start to about 70 little little trottle at full trottle it reads 10.5 to 12 as the rpms get high also the plugs are stll black around the treads and gray on the bottom also when i start the car it ildes lean i can't even see a number what should i do
Old Apr 29, 2007 | 09:40 AM
Snoopy's Avatar
Snoopy
been there done that
you need to get on a dyno and not rely on a basemap someone burned for you
Old Apr 29, 2007 | 11:31 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
You should tune your car, like everyone has said over an over again!
