How Do You Guys Mount Your Blocks to Engine Stands?
Old Oct 8, 2002 | 01:34 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Default How Do You Guys Mount Your Blocks to Engine Stands?
I was going to use the tranny bolts to put my spare block on my stand, but they're not even long enough to clear the brackets on the stand. I went to Home Depot, and the closest thing I could find was a 12mm X 1.75 thread, but that was too coarse. Then I was looking at the SAE fine thread stuff, and that looks like it'd match up alright, but they didn't have any in 1/2", which would be the closest thing to 12mm.:dunno:
Also, are flywheel bolts 14mm 12pt? I assumed they were, since the clutch bolts are 12mm 12pt, and my Helm's says the flywheel bolts are 2mm wider in diameter.
Old Oct 8, 2002 | 02:39 PM
wadzii's Avatar
wadzii
fear the dark side
flywheel bolts are 17mm 12 pt bolts.
as for the engine stand i usually use a nut and a bolt that will fit through the hole in the block. motor mount bolts also work.
Old Oct 8, 2002 | 03:09 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
17mm, and I thought they were 10's on the clutch... Too tired to remember that...
Old Oct 8, 2002 | 03:12 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
you're right, i just checked. looks like I'm 0 for 2
Old Oct 8, 2002 | 06:44 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I ran into the same problem this summer, I ended up just setting my engine on the ground after trying to find suitable thread material all over the place [I have one engine on the stand, but the stand was actually cut to let the bolts work]. Eventually I'll probably have a set of bolts made assuming I keep working with Hondas.
And yeah, flywheel bolts are 17mm, clutch is 10mm, both 12 pt.
-Harry
AIM: NDcissive
Old Oct 8, 2002 | 06:48 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Yah, my spare block has been sitting on my creeper for a week and a half. I don't mind leaving it there, since I can still move it around and I never really used the creeper anyway. However, the fact that I went thru the trouble of assembling my stand and now it's just taking up space does kinda bother me. I guess I'll just call around and ask for 12mm X 1.25 X whatever bolts.
Old Oct 8, 2002 | 06:50 PM
1stGenCRXer
Good luck, I think you need like 7" long and the higher the grade the better, no place I called local had them and I was on a tight schedule, maybe you will have better luck.
Old Oct 8, 2002 | 08:43 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
McMaster-Carr has the 12 x 1.25 bolts up to 80mm in length. But they sell them in packages of 50. They also have threaded rod in that size. One meter for $23.68.
Old Oct 8, 2002 | 09:47 PM
wadzii's Avatar
wadzii
fear the dark side
motor mount bolts work....... we got more than a few layin around so thats what we use
