8valve to 16valve head swap?
Old Sep 19, 2002 | 01:45 PM
EPrepCivic's Avatar
EPrepCivic
AutoX is in my blood
Default 8valve to 16valve head swap?
They say a 1993 Civic CX is slow because of the 8 valve head.
Can I bolt on a 16 valve head?
Not looking for a rocket, just a little more power, at a cheap price. (I know that REALLY doesn't exist but....)
Old Sep 19, 2002 | 02:09 PM
qtiger's Avatar
qtiger
If I remember correctly, the bottom end of the CX is really flimsy. But I believe the head swap would be possible.
Old Sep 19, 2002 | 06:41 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Do the CX pistons have the valve reliefs for a 16 valve head?
Old Sep 19, 2002 | 08:01 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I doubt the right valve reliefs are there.
SOHC VTEC and LS motors are both pretty cheap and they bolt in, I don't see the reason to stick with the CX block.
Old Sep 20, 2002 | 04:08 AM
EPrepCivic's Avatar
EPrepCivic
Bolt in is the main idea here. But how "bolt in" is bolt in.
I have my Civic, this car is suppose to be for the wife, so I can't go too crazy.
I have a 93 DX motor here. Is it a drop in to the CX. I would probably need to use the CX intake I presume in order to keep the wiring harness the same.
If it's a drop in, I'll just do that for the extra 20 Horses.
Old Sep 25, 2002 | 07:25 PM
93_lude_vtec's Avatar
93_lude_vtec
i assume that the dx is strait bolt-in, but i dont have much experiance though...i am also under the impression that the b-series motors are also, all i think you need is ecu and motor mounts for that engine, as long as its an obd I engine and ecu it should all plug right in
Old Sep 25, 2002 | 07:48 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Yes u can bolt up a DX 16 valve head to a CX block
i did this on my car. IT works fine the blocks are the same jsut the head are diff. I had not prob.
Old Oct 9, 2002 | 01:00 AM
qtiger's Avatar
qtiger
Update:
CXs have 4 reliefs.
https://www.honda-acura.net/forums/s...threadid=26729
PhillyD04
92+ Civic/EL & Del Sol
Feb 23, 2006 12:35 PM
socal nick
Jan 26, 2006 09:30 PM
elementgb
Jun 4, 2005 05:07 PM
concerto
CRX & Pre 92 Civic
5
Jun 24, 2004 01:08 AM
Turbo_Teg
Dec 10, 2002 08:10 PM
