4340 lightweight crankshafts
Old Apr 5, 2007 | 08:58 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
Default 4340 lightweight crankshafts
whats the deal with these?
would machining the stock crank be just as good?
Old Apr 5, 2007 | 09:07 PM
qtiger's Avatar
qtiger
Honestly, there's no good reason to use an aftermarket crank unless you are making truly outrageous (high 3 digits) horsepower.
Old Apr 5, 2007 | 09:12 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
4340 is a very strong steel alloy.
Eagle offers a 4340 Cro-moly lightweight crankshaft that comes with knife edged counterweights but it is very pricey. The stock crankshaft isn't made from the same materials but it can be lightened in the same fashion by a machine shop. Like qtiger said, the stock crankshaft is plenty sufficient for even super high hp applications.
Old Apr 5, 2007 | 09:55 PM
dubcac's Avatar
dubcac
I
Stock is fine, just get it balanced.
Old Apr 6, 2007 | 10:48 AM
Snoopy's Avatar
Snoopy
been there done that
only reason to run an aftermarket forged crank is if you're running a bigger stroke (92mm+)
the stock cranks can take whatever you throw at them.
Old Apr 6, 2007 | 05:38 PM
daddiodanger
bad mo fo
thanx,
just curious what everyone thinks
Old Apr 6, 2007 | 09:02 PM
dubcac's Avatar
dubcac
I
Yeap.
