B18B Valves
Old Apr 3, 2007 | 03:05 PM
FearTheTruth34's Avatar
FearTheTruth34
if i want to build the bottom end its gonna take a new bore, hone, pistons, and rods, and i really honestly dont feel like having that all done, way too expensive
Old Apr 3, 2007 | 03:11 PM
Snoopy's Avatar
Snoopy
been there done that
then you are severely limiting your potential with a built head. might as well just leave everything stock. how much do you think a built head is going to cost?
you can still get very good result with oem parts.
Old Apr 3, 2007 | 04:17 PM
FearTheTruth34
a built head with better flow will make a lot more power, even without a built block...my buddy has an ls-vtec, left the block alone, and left the head alone, just did cams, and makes over 200 whp
Old Apr 3, 2007 | 04:24 PM
Snoopy's Avatar
Snoopy
i find that very hard to believe
stock b18b compression is 9.5:1. good if you want to boost. not so much if you want to stay all motor.
Old Apr 3, 2007 | 06:09 PM
FearTheTruth34
ehhh with a gsr head the compression goes up to like 10:1 i think...all vtec heads have a smaller cc than nonvtec...
Old Apr 3, 2007 | 06:41 PM
Snoopy's Avatar
Snoopy
still, 200whp with only cams is very very hard to believe
