H-beam rods in a b18b block
Old Mar 30, 2007 | 07:49 PM
FearTheTruth34's Avatar
FearTheTruth34
Default H-beam rods in a b18b block
will it need to be notched?
Old Mar 30, 2007 | 08:40 PM
dubcac's Avatar
dubcac
I
Get the proper rods and everything will fit perfectly.
Old Mar 30, 2007 | 10:01 PM
FearTheTruth34
i want to do jdm p73's in my ls-vtec b18b block and crank, i was hoping b18c1 rods would fit onto my crank so i would not need to machine the top of the rod to get it to fit in between the wrist pin area of the p73...
Old Mar 30, 2007 | 10:18 PM
dubcac's Avatar
dubcac
I
If you're running an LS crank, you must run LS length rods. As you know, the LS has a longer stroke than the GSR, but the same deck height. If you run GSR rods on an LS crank, kaboom...piston hits the head.
Old Mar 31, 2007 | 11:25 AM
Snoopy's Avatar
Snoopy
been there done that
you cannot use forged rods with stock cast pistons unless you modify the rods to accept a press fit pin or modify the piston to accept c-clips.
just have the stock rods modified. it's only 1mm off each side of the small end.
Old Apr 2, 2007 | 04:18 PM
FearTheTruth34
yeah i saw that it was 1 mm off each side...ill look more into that
