how much more boost can my d16 handle
i have the jrsp boostin 9psi already. i've been told 10psi is the max. what i was wondering is if i could safely run like a 35 shot in 3rd, 4th, and 5th gear? i wouldnt ever run it in 2nd or 1st for they're really strong. if i lose a race its usually because i get passed in third fourth. i'm all low end.
engine: sohc d16y8 vtec
mods: jrsc w/boost upgrade (9psi)
dc sport short ram intake
you erased the one with all the mods! haha. guess i'll retype it.
stillen 4-1 ceramic header
greddy extreme cat back w/hi-flow cat
stillen fuel pressure riser
walbro 255 fuel pump
ngk plugs (colder)
jr boost timing retarder
will have with in the month:
apexi v-afc (to lean it out some, throwing a too rich code)
act clutch (hd-ss) (maybe flywheel depending on condition of current one)
i have a boost guage and air/fuel gauge as well.
ngk plugs (colder)
Originally posted by inspyral
I thought the JRSC loved short primaries, ie Kamikaze.
You might be able to pick up a good amount of horsepower with a Kamikaze header, some water injection, and some dyno tuning.
If you are throwing a too rich code, even occaisionally, you are running way too rich to make good power. $200 worth of dyno time may make more power than any expensive mod you could buy.
hey..i know someone with a slightly used Kamakazi 4-1 header...if your interested in it...its off a 2k Ex civic that was used for maybe 6months...lemme know if your interested in it...he may let it go for cheap
i'm not sure i know what you guys mean by short primaries? whats the difference between the 4-1 kamakazi and the
stillen 4-1? am i really going that much more power out of it? fill me in some more on the difference between the one i have and the kamakazi and i may be interested in selling mine and buying your friends if the price i right.
