ls vtec build
Old Jan 25, 2007 | 05:29 AM
ls_on_boost's Avatar
ls_on_boost
ls_on_boost
Default ls vtec build
hi i wanna build a ls vtec turbo and i'm thinking of going with srp pistons eagle rods i don't know what crank to use i wanna boost the most is 20 pounds i don't know if i'll get away with using a ls crank and get it welded how do you know how much you can boost with low compression piston what i want is to build the bottem end any ideas please let me know
Old Jan 25, 2007 | 05:42 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
The whole ls/vtec thing has been covered a ton of times, just click on the search engine and most likely you'll find answers to all of your questions.
Old Jan 25, 2007 | 12:16 PM
Snoopy's Avatar
Snoopy
been there done that
how much power do you want to make? how much money do you want to spend?
the ls crank is fine and will handle any amount of power you can throw at it.
Old Feb 17, 2007 | 12:02 AM
AcuraFanatic's Avatar
AcuraFanatic
Up to about 800HP or so.
Make sure you do ARP rod bolts.
Old Feb 17, 2007 | 01:31 PM
Snoopy's Avatar
Snoopy
go back to the basement hfawk:
Old Feb 28, 2007 | 07:56 PM
iceboy's Avatar
iceboy
its not ls/vtec without an ls crank
