blow by???
Old Nov 26, 2006 | 12:18 PM
tommyhcky13's Avatar
tommyhcky13
Default blow by???
can someone please ecplain blow by to me. i was driving yesterday and blew the pcv valve out. my friend said he thinks i have too much blow by. before the pcv valve blew out my car smoked bad(oil) but now it's really bad
Old Nov 26, 2006 | 12:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Blow by is combustion chamber pressure that has leaked past the piston rings into the crank case.
Typically, blow by is seen on turbocharged motors with poor tunes or spiking issues that have cracked ringlands causing low compression. It could happen on a stock engine with worn rings, though. Run a compression and leakdown test to make sure the rings are still holding decent compression.
Old Nov 26, 2006 | 01:40 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
i thought any engine will have a certain amount of blow by? i did notice my 00 civic si seems to have quite a bit of blow by...oh lord i hope nothing is wrong
Old Nov 26, 2006 | 01:45 PM
Provocateur
On permanent hiatus
Yes, there was always be blowby...even in a freshly rebuilt motor because the ring gap will still allow some combustion chamber gases into the combustion chamber.
Old Nov 28, 2006 | 12:20 PM
FooD2000's Avatar
FooD2000
Still Water
ah yes... blow by, the most hated thing for boosted hondas. How much smoke is coming out of your valve cover? If it's at idle and your getting puffs of smoke then you sir have craked ringlands. under throttle you should see some smoke which is normal.
Like Mr Schmoo said, Compression test will be your answer. Good luck.
Old Nov 30, 2006 | 11:55 PM
95LSv's Avatar
95LSv
Banded
How do you know when you experience a blow by?
Old Dec 1, 2006 | 03:57 AM
tommyhcky13
just a little smoke out of the valve cover, but when i get on it it's like a smoke bomb. like something from a james bond movie
Old Dec 1, 2006 | 05:47 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Sorry to sound dumb, When u say ringlands what does this mean? do u mean piston rings or sleeves?
Old Dec 1, 2006 | 11:38 PM
Provocateur
On permanent hiatus
Ringlands are the area of the piston between the rings. Those will crack with a poor tune. If the ringlands are cracked, new pistons are required.
