PM6 Tuning
Old Aug 22, 2006 | 06:20 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
D16a6 motors are very good. you can get as much power out of the than the vtec versions. They are also easier to tune as you dont have to mess with vtec. You also donot have to convert to OBD1 as there are ODB0 tuning tools Turboedit BRE... these are free and found at pgmfi.org
Old Aug 23, 2006 | 11:11 AM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
Thanks for the support
I've been doing some homework, and you're right about the tuning. I'm keeping my eye out for a PM6 out of a 90-91 Si so I can chip a new EPROM for tuning. I've found quite a bit of helpful info at xenocron.com for the chipping process and using TurboEdit. I'd like to find someone that can do the soldering for me and program the EPROM, because I just don't have the tools to do it right. I'd also like to find a good tuner in the area that has experience with TurboEdit.
Old Aug 23, 2006 | 07:39 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
xenocron can help you out alot. Just email him. He helped me out when I first started tuning.
Old Aug 23, 2006 | 09:05 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you haven't signed up yet, check out http://forum.pgmfi.org has a turboedit section that has a wealth of information on tuning OBD0 systems.
Old Aug 23, 2006 | 11:36 PM
PacificDude
Sharkbait OOHAHA!
Thanks Schmoo, I just signed up over there.
I'm planning to stick with the stock compression ratio(9.1:1), so I'm wondering if it's actually necessary to chip and manually tune a PM6, or if the stock basemaps are sufficient. I posed that question over there, so I guess I'll find out soon enough.
Old Aug 24, 2006 | 08:34 AM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
yeah but your still going to port and change the cam right these will affect air fuel ratios. So you will need to tune.
Old Aug 24, 2006 | 02:29 PM
Provocateur
On permanent hiatus
Not just fuel ratios, but also ignition timing.
Even a stock motor can benefit a little bit from more aggressive ignition maps, if so desired. I would say that tuning is a great idea for both power and longetivity.
Old Aug 26, 2006 | 08:17 PM
AcuraFanatic's Avatar
AcuraFanatic
Stock ECU maps would be useless. I'd look into Hondata, Crome or Neptune. Somebody will have a map for the ZC.
Old Aug 26, 2006 | 09:01 PM
Provocateur
On permanent hiatus
Those are all OBD1 roms. Unless he converts, those aren't an option.
Old Aug 26, 2006 | 10:23 PM
PacificDude
Sharkbait OOHAHA!
I will not be converting, so it looks like I'll be picking up a 90-91 Si PM6 and installing a new EPROM. TurboEdit will be just fine. I'll start with the base fuel maps and find someone who knows how to use TE to get the most out of my build.
I wonder if I could use Prelude injectors to supply more fuel. I think the stock CRX injectors are 220cc and the Prelude injectors are 260cc. I think that would be plenty for an N/A build :dunno:
