idle problems
Old Jun 18, 2006 | 04:55 PM
88'CRX's Avatar
88'CRX
Default idle problems
I have a b18a1 and the idle is not smooth at all. it goes from around 1500 then drops to under 1000 then goes back up to around 1500 and repeats itself does anyone know what causes this and how do i fix it?
Old Jun 24, 2006 | 10:34 AM
ricunger's Avatar
ricunger
try some gum cutter 2+2 in the tb and check your wires with a multimeter. dont for get your plugs too. are there any codes?
Old Jun 29, 2006 | 01:28 PM
JasonST's Avatar
JasonST
Does it only do this when it's warm, or cold? Check for vacuum leaks, check and clean ur IAC (Idle air control valve).
