EG w/H22 injector question
Old Jun 22, 2006 | 03:54 PM
nblanton's Avatar
nblanton
Default EG w/H22 injector question
I just got a '92 CX with an H22A4 in it. It was pretty poorly setup and I'm fixing the issues with the car now. I've picked up a P13 ecu, a H22A1 OBD1 complete harness, and some better mounts. The question is, I know that the OBD1 'lude came with low-impedance injectors and I plan on switching either to the 345cc injectors that were supposed to be in an OBD1 H22 or some 360cc DSM's. (Mainly because they are a lot cheaper) So, do I still need a resistor box to run the low impedance injectors, or with the ECU work with them with out it? Oh, and by the way, what axles should I run? I've done a few B swaps, but this is my first experience with an H22 civic swap.
Old Jun 29, 2006 | 01:31 PM
JasonST's Avatar
JasonST
I'm pretty sure u'll need a resistor box since it's obd1, I could be wrong though. I'm running DSS axles with my h22 swap, and it's been running great with no problems, but if u don't have enough money u can go with some integra axles with prelude inner cv joints, the correct axles are on Jdmshit.com
