jrlovejoy
Old Jun 14, 2006 | 05:43 PM
jrlovejoy's Avatar
jrlovejoy
Default Non starting Integra
1990 Integra - My integra ran fine at lunch and then when I went to leave in the evening, it would not start. The engine cranks but will not fire. I don't know if I'm getting spark, but the distributor is only four months old. I have't heard the fuel pump. Any Suggestions?
To further address this problem. The ambient ouside temperature was 102F. When I tried to start the car on the next day it started right up.
Diagnosis: It's probably the Main Relay Assy.
Old Jun 15, 2006 | 01:15 PM
AcuraFanatic's Avatar
AcuraFanatic
If you haven't heard the fuel pump, it's probably the fuel pump.
Check for spark and fuel obviously. Check for blown fuses or a bad relay that may have sent the fuel pump into dormancy.
Or it simply could have failed.
