Poor gas mileage??
Old Jun 10, 2006 | 11:43 PM
95LSv's Avatar
95LSv
Banded
Default Poor gas mileage??
I wonder how many miles you guys are getting for a full tank. I am currently at 104 for a half a tank with my b16. Is this normal or should i be getting more? I replaced the fuel filter, if my miles are too low, what else could I do??
Thanx
Old Jun 11, 2006 | 11:41 AM
hooptie's Avatar
hooptie
I get about 230 or so for half a tank.
Old Jun 11, 2006 | 12:23 PM
jerry00's Avatar
jerry00
Thanx
i get around 250 miles on a half tank also...that's around 30mpg for the full tank on my car.
Old Jun 11, 2006 | 01:51 PM
95LSv's Avatar
95LSv
Banded
wow above 200... My mileage sucks... Does anyone have any suggestions on what it may be? Also i am not even smashing on the car, driving it real nice and slow to break it in...
Old Jun 12, 2006 | 12:51 AM
95LSv's Avatar
95LSv
Banded
Anyone?
Old Jun 12, 2006 | 11:21 AM
Tankard's Avatar
Tankard
Check to see if all your vacume lines and hoses are properly connected and not pinched or leaking. A clogged pcv valve or fuel filter can also cause poor fuel mileage along with numerous other things. I'd recommend a tune up, along with what i mentioned above. I, once, accidentally left the bottom line( the line that goes into the firewall) to my charcoal canister disconnected after changing my fuel filter, and it caused chitty gas mileage.
Old Jun 12, 2006 | 01:18 PM
95LSv's Avatar
95LSv
Banded
Well this engine is new, just built like a month ago. New distri., new internals, timing belt, plugs, wires... I connected all my vacuum lines too, but maybe incorrectly. Is there a diagram anywhere for vacuum lines?
And could it be the fuel pump or injectors, because I had poor gas mileage w/ my other motor as well..?
Old Jun 14, 2006 | 12:35 AM
95LSv's Avatar
95LSv
Banded
Can anyone please help? Can it be the fact that im using a p72 ecu w/ b16 motor? My friend recomended that i get the ecu chipped and have him retune the fuel maps, would this work??
- Could it be the b18 injectors?
- Fuel pump??
Old Jun 15, 2006 | 12:11 AM
95LSv's Avatar
95LSv
Banded
Well we replaced my ls injectors and fuel pressure regulator with gsr ones today, but i doubt that will solve anything... The thing is if it was BURNING too much fuel u could see it either coming wout the exhaust or plugs would be black. My plugs are in the perfectest condition i have ever seen, the are GOLDEN Brown. Does anyone think there could be a leak in the gas tank or something?? :noes:
Old Jun 15, 2006 | 09:38 AM
sharnee.brown's Avatar
sharnee.brown
i have a pr3 ob1 ecu ill trade for the p72. it was made for the b16
