black smoke??
Old Sep 23, 2002 | 02:02 PM
integracer's Avatar
integracer
Default black smoke??
i have black smoke comin out off my exhaust at around 5 grand
and a little just ridin
i ahve been told it was carbon build up and its runnin to rich
if so what would i have to to to fix this:thumbup:
Old Sep 25, 2002 | 09:31 AM
c-c racing's Avatar
c-c racing
your car is getting to much fuel its running rich check your fuel pressure
Old Sep 25, 2002 | 10:28 AM
kaneda3's Avatar
kaneda3
so then what is faint white smoke
oil?
i have a b18a1 and turbo
is it possible my turbo is blowing oit into my intake manifold and is that somewhat normal?
thanx
Old Sep 25, 2002 | 11:30 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You can clean out carbon from an engine using water or using a special detergent running through a vaccuum line on the intake manifold. If you're iffy about doing any of this on your own, take it to a shop that will do it for you.
"White" smoke can be oil or coolant, depends on the smell and how heavy it is as to how well you can identify it.
-Harry
AIM: NDcissive
Old Sep 25, 2002 | 02:23 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
ATF has detergents in it that break up carbon:thumbup:
Old Sep 25, 2002 | 02:24 PM
1stGenCRXer
Ah, true, forgot that one :thumbup:
Old Sep 25, 2002 | 05:47 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Water!? How is that done safely??
Old Sep 25, 2002 | 07:14 PM
1stGenCRXer
By using a spray bottle and not a water hose or puddle.
Old Sep 25, 2002 | 09:09 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Honda sells some stuff called "Top End Cleaner" that basically gets sucked thru a vac line like 1stGen said. It comes in a can and is like $4 per can. The cans are kinda funky, so you need an iduction tool that's like $30 to use em. The part numbers for the cleaner and tool are 08732-9008 and 08732-9010 respectively, but I would just use some water or ATF. The key is small amounts at a time sucked thru one of the vac lines on the intake manifold.
Old Sep 25, 2002 | 09:15 PM
dubcac's Avatar
dubcac
I
Oil burning is a whitish/bluish smoke.
Running925
92+ Civic/EL & Del Sol
22
Mar 31, 2005 05:52 AM
