97 ls turbo hp?
Old May 22, 2006 | 06:36 PM
97-tegowner's Avatar
97-tegowner
Default 97 ls turbo hp?
i built a turbo kit with a tubular mani, 14b turbo(1g talon) 22x7x2.5 intercooler running 7 psi with an FMU does anyone know how much hp i will have at the wheel(educated guess) thanks
Old May 22, 2006 | 06:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Probably not much considering the turbo is tiny and the fuel management is half assed.
Old May 22, 2006 | 06:56 PM
97-tegowner
ass
Old May 22, 2006 | 07:04 PM
Provocateur
On permanent hiatus
Originally Posted by 97-tegowner
ass
You asked a stupid question and got a stupid answer. Get over it.
If you want to know numbers, strap it to a dyno. Bench dynos are for posers.
Old May 22, 2006 | 07:07 PM
97-tegowner
i was asking in case someone else was running a 14b with an fmu not to be made fun of by someone thanks for all your help though
Old May 23, 2006 | 06:16 PM
mberndt's Avatar
mberndt
Well I got a 14b...
How do you consider that tiny? ---> Yes, not as big as a T4 compressor wheel, but it is well suited for a b-series... Have you ever done an analysis with a
14b? Besides it is better for a street engine IMO...
I do have good fuel management, though so it does make a big difference...
7psi? LS you could push like 12psi at least, maybe 8 on a B18C.
I'm running B16 block, LS pistons, GSR head, ---> C/R=8.75 Uberdata and 450DSM injectors, ACT clutch, among other things...
I'm running conservatively at 10psi on my 14b, and IMO it's faster than a friends T3/T4 at 8psi...
Old May 23, 2006 | 07:11 PM
Provocateur
On permanent hiatus
Originally Posted by mberndt
Well I got a 14b...
You just answered your own question. I never said tiny was a bad thing. I have a tiny turbo too and it is great for daily driving since it spools up really quickly. I, however, don't expect insane power numbers out of it.
I meant to emphasize the half assed fuel management. It will make it less reliable, won't be making its full potential in power, and the gas mileage will suck.
Old May 24, 2006 | 04:36 PM
mberndt's Avatar
mberndt
Yeah, I guess I did, LOL...
I totally agree with you...
Bad engine management = Bad engine performance
What size turbo r u running anyway, 18G?... 204ft-lbs =
Old May 24, 2006 | 05:46 PM
Provocateur
On permanent hiatus
Yeah, an 18G. It isn't all that big, but for stock internals and 149k miles, it is plenty of turbo for me.
I was pretty amazed by 204 ft/lbs since I street tuned it myself and didn't even mess with the ignition map. I am sure that if I tune the ignition maps more aggressively, I could squeeze more hp and torque out of it, but there is no reason to. Having more than 180 ft/lbs of torque after 3800k rpm makes it a very fun street setup.
