P28 chipped ecu
Old May 4, 2006 | 09:22 PM
95LSv's Avatar
95LSv
Banded
Default P28 chipped ecu
I am going to run a p28 with my b16 motor. The ecu is chipped, vtec 5500, and redline at 9000, i don't know what else... I am just wondering of how good a p28 ecu is...??
Old May 4, 2006 | 10:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They seem to be the choice for vtec ecus because they are cheap and get the job done.
It will be fine for your application except for the fact that it doesn't have knock sensor support, so you want to always put 91 or higher octane in and make sure the ignition timing is to spec (16* +/- 2* BTDC at 750 rpm).
Old May 4, 2006 | 11:30 PM
95LSv's Avatar
95LSv
Banded
crap... if it doesn't have knock sensor, ill probably end up getting a gsr one...
