Throttle Position Sensor
Old May 4, 2006 | 05:01 PM
jay169's Avatar
jay169
Default Throttle Position Sensor
Does anyone know where the throttle position sensor is located in a 98 Civic HX manual? Also, what are the symptoms when either thats bad or there is a leak in a vacuum hose? i described my symptoms to someone, and thats what they came up with.
Thanks guys.
Old May 5, 2006 | 06:14 AM
teg92's Avatar
teg92
WHAT OK YEAH!
it should be on the throttle body along with the map sensor
Old May 5, 2006 | 10:45 AM
96tegls2dr's Avatar
96tegls2dr
yes it is on the throttle boby. you can acutally test to see if its working by unplugging it. this will put the ecu into limp mode and it will run off of the ecu preprogrammed values instead of the sensors. this also sets the CEL. so if you unplug it and the problem goes away you know that is the culprit. if it doesnt stop the symptom reset the ecu by unplugging the battery for about 15minutes to get rid of the CEL and move on to your next diagnosis. if it is a vaccum line you can spray the vaccum lines with carb cleaner while theengine is running and if the rpms increase the area that you just sprayed is the leak.
does the car idle correctly or is it just doing it under load???? if it idles wrong or jumpy then it most likely is a vaccum leak
