Radiator Fan does not turn on
Old May 1, 2006 | 04:55 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
Default Radiator Fan does not turn on
My Radiator fan does not want to run. Its not the stock, its a univeral flex-a-lite fan. Here comes the problem though. I disconnect the harness from thermoswitch (the switch by the thermostat) and run a bypass and the fan runs and it stays on. I think the obvious thing to do would be to change the thermoswitch. I did, but the fan still doesn't come on. The car's temp eventually start to get hot, so I would say that it overheats then. My friends and I are stump now, and we can't make out how it works with a bypass but the thermoswitch is not the problem . Any ideas?
Old May 1, 2006 | 05:01 PM
ariza034's Avatar
ariza034
SuMaDiNaC
water pump maybe air bubles in the system /.... i dono i was gonan say thermostat but u said thats not teh problem
Old May 1, 2006 | 09:20 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
i have the same problem. did you rewire your thermo, i had to for my swap.
Old May 1, 2006 | 09:31 PM
cvchtchbck92
Anti-Ebayer
Let me just add a couple of other things. Alright, I did a B18C swap. However, since the wiring harness was backwards, I used my stock harness (D15B8 or Civic CX). I have an ARC Thermostat.
Old May 1, 2006 | 09:32 PM
cvchtchbck92
Anti-Ebayer
Can you explain more on what you just said? It may be that or I would like to try it, at least.
Old May 5, 2006 | 01:22 PM
cvchtchbck92
Anti-Ebayer
Thank you everyone. There was air in my cooling system. We "perged" the system and all the air was coming out. Shortly after, the fan came on. Thanks again.
