horn keep going off!
Old Apr 26, 2006 | 10:03 AM
civic401's Avatar
civic401
Default horn keep going off!
hello everyone.. i was driving home from work and everytime i hit bump the horn will come and wont turn off unless i pull out the fuse. when i'm on a roungh road, i heard this clicking sound coming from the stearing wheel then all of sudden it goes off. any idea where i should look? how to you remove the air bag cover? also anyone have this problem before. i drive a 98 civic lx. thank you.
Old May 2, 2006 | 08:29 PM
civic401's Avatar
civic401
any know where the horn relay is at? i found out that clicking nose is coming from under the desk by my fuse box.. it only clicks when i hit a bump.. if anyone provide me with a diagram of the relay location. Thanks
it's a 98 honda civic LX.
Old May 2, 2006 | 08:38 PM
90CvcDX's Avatar
90CvcDX
kekeke
i had this issue but with an aftermarket steering wheel, something electrical is probably making contact behind the steering wheel, you can either bend the little tab back or check the connections
