2.3vtec oil jet discussion
Old Sep 19, 2002 | 06:10 PM
93si4ws's Avatar
93si4ws
ChinoRN
Default 2.3vtec oil jet discussion
to end this discussion...and if anyone cares...you cannot use the vtec oil jets in a 2.3 block. while it will definitely bolt up, it will pose problems for other parts. its not the crank that is the problem although they came very close. the problem is the piston, before it can reach btdc it will touch the oil jet. so there goes that idea.
for enlightening purposes...i had put in my balanced 2.3 crank into my jdm 2.2 block with the oil jet installed. i just put in my pistons/rods (type s pistons/usdm 2.3 rods) today, and i found the true reason it will not work as stated above.
hope this helps with any confusion
v
Old Sep 21, 2002 | 04:24 PM
Trickturn's Avatar
Trickturn
Balls or just crazy...
you can shave down the skirts on the pistons so they will clear, or you can put shims under the oil squirters
Old Sep 22, 2002 | 09:11 AM
93si4ws's Avatar
93si4ws
ChinoRN
you can't shim the jets. that will make them touch the crank, and will throw off the direction of the oil flow.
and i was thinking of modifying the pistons, but i already had everything balanced and i wasn't going to ruin that.
v
BOMBCRU
Vehicle Classifieds
Apr 22, 2005 11:24 AM
BOMBCRU
Vehicle Classifieds
3
Apr 22, 2005 09:04 AM
93si4ws
Vehicle Classifieds
7
Jul 26, 2004 12:14 AM
93si4ws
Prelude
24
Oct 30, 2002 07:14 PM
93si4ws
Prelude
6
Oct 21, 2002 09:45 AM
