Raising compression reving 10!?
Old Mar 17, 2006 | 04:04 PM
Si_Opps2's Avatar
Si_Opps2
Default Raising compression reving 10!?
Im in the process of building my b16a2 head. I want to get some serious power with good tuning through hondata reving to atleast 9.5 hopefully 10. How can I sufficiently raise my compression to cope with such high reving. I dont want to build the block too much because I would like to do a GSR block swap after a while. Like which pistons and other components would be best for what I am trying to accomplish.
Old Mar 17, 2006 | 04:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You will need cams that make power that high. I would be more worried about an accurate spark at 9k rpms and up. You just won't get it with a distributor.
I just don't see the point of revving that high....I guess it is a macho thing or something. :dunno:
Old Mar 17, 2006 | 07:49 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Indeed... I tuned/built mine to go to 9700 but set it at 9400 because it only made power that high. Why not build for a specific whp/wtq number and build for that? RPM you can revv it to is irrelevant in the way of power...
Old Mar 17, 2006 | 08:47 PM
Provocateur
On permanent hiatus
Just a curiousity question...where those the ITR cams that made power that high? If so, I am surprised.
Old Mar 17, 2006 | 09:01 PM
westcoaststyle
They were. JDM ITR cams, omnipower springs, titanium retainers (forgot what brand), and OEM GSR valves. Had AEM cam gears too.
Old Mar 17, 2006 | 09:06 PM
Si_Opps2's Avatar
Si_Opps2
So skunk2 stage 2's wont make the power?
