K20 EK Hatch Build 100+ pics!!
Old Mar 14, 2006 | 07:39 PM
DigitalShift's Avatar
DigitalShift
Originally Posted by goon54
DAMN!!!!!
my paint didnt come out anywhere near that perfection..............
keep up the gr8 freakin work dude!
Let me see some pics of your car... I'm curious. I've seen one other car this color and it was on an EK hatch..
The Clear tubing will not cave in, it is reinforced with threads to keep it from doing that. Also, my catch can is hooked to the PCV valve so it's not under any serious serious vacume. There are certin types of hoses like this, some are for fluids, some arent. These are coolant lines or anything so I doubt the temp is going to get hot enough to melt them.
2006bb6: Pardon my ignorance, but what is a J32 N2?
Old Mar 14, 2006 | 07:44 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Well, don't say I didn't warn you. I had the exact same tubing with my Greddy 9mm can and it got hot enough in the engine bay to make the tubing plyable so it was sucked shut. Mine was hooked up between my PCV valve and my intake as well. I upgraded to steel braided and never had to worry about it again...
Old Mar 14, 2006 | 07:55 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
id like to know what a J32 N2 is also????
Old Mar 14, 2006 | 07:59 PM
goon54's Avatar
goon54
[QUOTE=DigitalShift]Let me see some pics of your car... I'm curious. I've seen one other car this color and it was on an EK hatch..QUOTE]
here's a old crappy pic in this link. mines not a hatch though
https://www.honda-acura.net/forums/s...d.php?t=165521
the paint job was rushed....bumper is a tad bit darker than the rest of the car. i WISH i had done it like urs, having everything stripped..
Old Mar 15, 2006 | 05:56 AM
DigitalShift
It looks good, the painter was about to spray my whole bumper when I got to the shop and I made him stop and tape it all up..
I understand what he was saying... J32 n2 (into) something.. but I still dont understand what a J32 is.
Old Mar 15, 2006 | 01:36 PM
2000bb6's Avatar
2000bb6
i ment to say a j32 INTO a EK
j32=CL/TL motor(V6).....im takin a CL Type S motor and six speesd trans and putin it INTO a ek
Old Mar 15, 2006 | 04:37 PM
AcuraFanatic's Avatar
AcuraFanatic
Nice man. Very clean. I'm almost at:
with mine.
Old Mar 15, 2006 | 07:39 PM
dfromny's Avatar
dfromny
Wow, looks great! Super clean!
Old Mar 16, 2006 | 01:35 PM
DigitalShift
I'm going to ask why?
1. It's not going to fit. Anything short of a full tubular front chassis and it wont fit. Gaurenteed.
2. Whats the benefits? Your going to put so much weight in the front of the car.
3. Wiring. Good luck getting the car to crank, I'm not sure who (if anyone) makes a stand alone engine management and if you can get around the immoblizer.
4. Fabrication. Custom mounts, shifter brackets, axles, hood, firewall, shock towers.. ect ect Everything will have to be custom made.
If your serious about doing this, I wish you luck. If you can pull it off and make it work..my hats off to you. But I dont know what it is about a V6 that makes people want to put them into a civic..at least in the front. Want to do something awesome, put the V6 in the rear of the car. Make is a mid-engined Civic... that would be way cooler than having a 6-700lb engine in the front of the car.
Just my 2 cents.
Old Mar 16, 2006 | 02:31 PM
westcoaststyle
Well said. :yes:
