nonvtec-vtec head?
Old Sep 17, 2002 | 10:31 AM
xbladr's Avatar
xbladr
Default nonvtec-vtec head?
Hey i have a dx i was wondering to increase power should i get a vtec head. Also how much hp would that increase and how hard would it be to install. The second thing is would i need a new ecu for that? The last thing is does anyone know how the venom 400 module works and if its even worth the money? thanks
Old Sep 17, 2002 | 01:09 PM
qtiger's Avatar
qtiger
You can get a VTEC head (epx has 2, if you'll looking for one). Should give you somewhere around 10-15 horse with no other modifications. The other 10 horse would come along with a VTEC intake manifold, VTEC style header instead of the close coupled cat, etc.
It isn't easy to install but not difficult either. You'll need to properly seat a headgasket and do some wiring.
You'll need a VTEC ECU, yes.
Venom 400 is totally worthless, don't even waste your money.
Old Sep 18, 2002 | 09:58 AM
xbladr's Avatar
xbladr
Also could i put a d16z6 head on the one from the 92-95 civics? if i did do that would it still be easy to install and would i have to get like a conversion harness and stuff thanks
Old Sep 18, 2002 | 01:39 PM
AwwsChwA's Avatar
AwwsChwA
all of the 88-02 D-series SOHC 1.6L engine blocks and heads are interchangeable, just like the B-series DOHC engine parts. If you want more power out of a DX, honestly your best bet is going to be just putting in a complete D16Z6 or D16Y8. The DX blocks have a shorter piston stroke, so whether or not you put on a VTEC head, you won't have the power of a stock Z6 or Y8 engine.
If you want to stick with a SOHC engine, a good engine combo to go with to get more power than a stock SOHC VTEC engine, is to combine a D16A6 block (88-91 CRX Si) with a SOHC VTEC head. The A6 block uses slightly domed pistons (sohc vtec engine has dished pistons), so you get higher compression than a stock SOHC VTEC. And if your civic DX is 92 or newer, a SOHC VTEC ECU will plug right into the existing harness. You'll probably need to wire in two more injector wires, though. If your civic is 88-91, Zdyne makes an ECU conversion so that you can install the VTEC head, and it will run with all the factory safeties and fuel curves and such.
Old Sep 18, 2002 | 07:13 PM
slow_civic's Avatar
slow_civic
_
Old Mar 13, 2004 | 07:56 PM
Rex-MiniMe's Avatar
Rex-MiniMe
Hate list:Hicks, Altezzas
Hey, I am doing my mini-me setup right now, but as I was rebuilding the bottom end in this 91 DX block (D15B2) I broke a chunk off a piston. The only thing that is available at this point in time is a 95 DX block (D15b7). The PM3 and PO3 pistons are said to be exactly the same but marked different for the newer OBD-1 block they came in. I need to get this running now, and that block is all I got. Do you think the piston is the same CR (compression ratio?) as the '91?? I need to know quick. They look almost exact but looks can be decieving.. Someone help me out while Im here.
abw
Dec 24, 2005 03:28 PM
pomansouth
Engine Swaps, Tech & Tuning
2
Nov 21, 2004 10:35 AM
RpG~^_^~LauRnO
Sep 27, 2004 06:09 AM
NWHondaman
Apr 30, 2003 09:50 AM
Turbo_Teg
Dec 10, 2002 08:10 PM
