b16 surges vacuum ? plz help!!!
Old Jan 11, 2006 | 12:22 PM
civiclyminded's Avatar
civiclyminded
Default b16 surges vacuum ? plz help!!!
have a b16 in a 95 si motor is a older b16 the surges need vacumm diagram .....or any insight... car sits at a light and bounces from 1500 tp 2500
Old Jan 11, 2006 | 01:00 PM
shivers's Avatar
shivers
Moderator Alumni
Check all the lines running to and from the intake manifold for cracks, cuts, or bad connections. Check the nuts/bolts on the manifold to make sure they're torqued properly. Check if there's any damage to the intake manifold gasket.
These are the places to start. Good luck.
2005 s2000
Old Jan 11, 2006 | 01:09 PM
civiclyminded
you have any pics to see if vacumm is right pretty sure it's not!!!!!!
Old Jan 11, 2006 | 02:34 PM
civiclyminded
where does the map go? it's not in the intake manifold... it has a hose on it, does that go to the top of the tb. ???? what about hoses from the canister does that get a tee with the map? thank you please help really pain in the a$$
Old Jan 11, 2006 | 07:30 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here are all the vacuum diagrams you need: http://photobucket.com/albums/c241/k...a%20Technical/
Old Jan 12, 2006 | 04:36 AM
civiclyminded
the b16a2 diagram {2000 si} doesn't seem to match up to my hoses, that are on my plentium..... is it different on a b16a1 ????
Old Jan 12, 2006 | 06:25 PM
shivers's Avatar
shivers
Moderator Alumni
Schmoo to the rescue.
The lines should essentially be the same, but depending on the year and origin of the engine (JDM, US, etc.) they may be in a slightly different location.
Take some pics of your bay and maybe we can help you get things sorted out.
2005 s2000
