acura legend will not start
Old Dec 19, 2005 | 10:15 AM
sklansek's Avatar
sklansek
Default acura legend will not start
1990 Legend
120,000 miles
About a year ago I started having a problem starting the car. It would turn over but not start. After waiting about 1 hour it start, run fine and give no problems for maybe 3 months. Then it would do the same thing. This winter it would happen about every 3 days. That lasted for 2 weeks and now it will not start. It has been sitting for 4 days now. Any thoughts. Oh by the way I had a mechanic check it out when it first happened but he found nothing wrong.
Old Dec 19, 2005 | 08:48 PM
HallKemar's Avatar
HallKemar
15yrs old, who cares why it wont start?
Old Dec 20, 2005 | 08:51 AM
mr.crx's Avatar
mr.crx
dude shut up if your not going to help dont say anything your not funny either...
check all your power sources and it may be the starter
Old Feb 12, 2006 | 12:30 PM
remoob's Avatar
remoob
I am having the same problem with mine right now. I was told to check the fuel line for fuel pressure. problem is i cant seem to find where the fuel line connects to the engine
Old Feb 13, 2006 | 07:44 PM
92b18hatch's Avatar
92b18hatch
i heard somthing about the main relay going bad in thoose cars and it wouldnt start, try replacing that
Old Feb 14, 2006 | 05:43 AM
AcuraFanatic's Avatar
AcuraFanatic
Main relay as suggested. I'd also honestly look to see if your car's timing is off (belt might of jumped).
If it's only starting dependant on weather it's a slight possibility.
Old Aug 14, 2006 | 08:46 AM
hpaynter's Avatar
hpaynter
I have a similar problem with my 92 Legend. Starts sporatically, sometimes immediately after hearing a barely audible click behind the firewall (perhaps on the passenger side). It starts eventually everytime, but sometimes it takes more than 30 minutes.
If this could be the "main relay" where is that located? I've checked all relays in the fuse boxes I know of in the engine compartment and they seem to be OK.
Any help?
Old Aug 19, 2006 | 01:50 PM
thegoldversion's Avatar
thegoldversion
Default engine will crank but wont start
i have a 91 legend, that click you hear is the main relay. the main relay is located in the driver side under the steering wheel on the left side it is easy to see its a black box and it will say mitsuba relay assy,main r z-0105, its about $80 at the dealer im poor so i took the bord out of the black box and zip tied it so it wont touch nothing and when the legend wont start i just tap the relay and it will start right up ,i know its ghetto but it works .and untill i get spare cash then i will buy a new one .
Old Aug 26, 2006 | 08:18 PM
AcuraFanatic
Main fuel relay is a very common problem with older Hondas.
