Skunk2 manifold inlet size?
Old Sep 11, 2002 | 03:11 PM
LeftCorner's Avatar
LeftCorner
Default Skunk2 manifold inlet size?
Anyone know the diameter of the inlet on the Skunk2 intake manifold (the part that mates with the throttle body) for the 94-01 GSR? Just wondering if a 62mm throttle body would be overkill or if I should stick with something smaller.
Old Sep 24, 2002 | 09:03 AM
taylormadem5's Avatar
taylormadem5
they make lager throttle bodies...62mm isnt that big..i think the stock tb on an ITR and CTR is like 64mm...and spoon makes one thats 70mm..BIGGER IS BETTER the more air you can get in there...the better it is cause you ultimately controll the position of the trottle...make sense..??
Old Sep 24, 2002 | 09:57 AM
qtiger's Avatar
qtiger
Stock TB on an ITR and I believe also the CTR is 62mm.
Just as with exhaust, bigger is not always better. There's a proper size for every application. Intake air velocity is a large factor in the performance of your engine.
62mm will by no means be overkill, that would be my recommended starting point. I'd need to know more about your application and goals before recommending anything else.
Accordfrek
Accord
Jan 14, 2009 07:47 PM
jdm style ef
May 28, 2007 03:23 PM
JMcDB18C
Feb 15, 2005 06:12 AM
chimchim
Engine Swaps, Tech & Tuning
2
Dec 26, 2003 08:18 PM
