Benifit of getting Hondata on stock engine?
Old Nov 18, 2005 | 07:43 PM
dresden_k's Avatar
dresden_k
RIP H22A-CB7 :(
Default Benifit of getting Hondata on stock engine?
Hi.
Would there be any gains to be made by getting a Hondata setup in my otherwise stock H22A w/ I/H/E?
If I also got an ignition coil, MSD Digital SCI+, fuel rail, 550cc injectors, 255 Walbro pump, etc... would I see any appreciable gains?
I ask this clearly idiotic question because I'd like to prep for turbocharging and I'd like to have as many auxilliary parts installed before I pull the engine, get a new header and install the turbo specific parts... And, yes, I know, I'll need to retune the Hondata when that all goes in...
But, to focus on the original question - what gains from Hondata + IHE + fuel system + ignition upgrades?
Thanks. :joshers:
Old Nov 18, 2005 | 08:08 PM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by dresden_k
Hi.
Thanks. :joshers:
You may notice a few hp, but not much. maybe 3-5hp.
You do know that you will be removing this "new header" that you plan to buy when you do go turbo right??
Old Nov 18, 2005 | 10:12 PM
dubcac's Avatar
dubcac
I
You're gonna run insanely rich with 550's on a stock motor...ignition is worthless...just wait until you go turbo for the fuel pump, injectors, and hondata.
Old Nov 19, 2005 | 12:37 AM
dresden_k's Avatar
dresden_k
RIP H22A-CB7 :(
Yeah I know my 4-2-1 header is coming out when I turbo.
So the consensus is just to wait and do everything at once?
Old Nov 19, 2005 | 06:50 AM
b16ahybrid's Avatar
b16ahybrid
Thats what hondata is for.....550's will run like stock
Old Nov 19, 2005 | 06:51 AM
b16ahybrid's Avatar
b16ahybrid
You mentioned getting a new header thats Why I pointed that out.
You'll save money by only tuning once if you do it all at the same time (turbo).
Old Nov 19, 2005 | 05:14 PM
dubcac's Avatar
dubcac
I
I don't know if you can trim the injector THAT much...that's pretty big for a stock motor....well over double the stock size.
Old Nov 20, 2005 | 12:02 AM
dresden_k's Avatar
dresden_k
RIP H22A-CB7 :(
Off topic, but I thought that prelude injectors were 385cc?
Old Nov 20, 2005 | 09:54 AM
b16ahybrid's Avatar
b16ahybrid
I have some 756cc injectors in right now that idle just fine, i'm going to be stepping up to 1000cc soon enough.
Old Nov 20, 2005 | 09:57 AM
b16ahybrid's Avatar
b16ahybrid
some are....I believe that obd-2 are....correct me if i'm wrong
