swapping cams- need pics!
Old Nov 18, 2005 | 04:38 PM
stemyluv69's Avatar
stemyluv69
Default swapping cams- need pics!
Im buying cams tonite for my 97 gsr and wanted to see a few pictures of a b18c with the valve cover off. Close ups would be nice How long should it take to replace just the cams? Also, do you think its imperative to go from a gsr to itr valvetrain with skunk2 stage 1 cams? Thanks in advance HAN homies
-Don
Old Nov 18, 2005 | 10:14 PM
dubcac's Avatar
dubcac
I
It's not necessary to go with the ITR valvetrain...but I probably would down the road. Here's a complete how to cam install, with pics.
http://www.c-speedracing.com/howto/caminstall/cam.php
Old Nov 19, 2005 | 06:08 AM
stemyluv69's Avatar
stemyluv69
dubcac, you da man Sounds stupid, but hows the belt come on and off so easily? Ive never seen a honda tensioner before. Any special tool? Throw me some more knowledge
Old Nov 19, 2005 | 06:56 AM
b16ahybrid's Avatar
b16ahybrid
Nope I believe it's a 14mm socket that loosens the bolt and allows the tensioner to move (it's on a spring, don't remove the bolt completely just loosen it enough to move the tensioner)...
Go to http://www.redpepperracing.com/techn...492c81528cc3d4 for torque specs.
Pretty easy install. Be carefull not to loose the cam keys they are small..
Old Nov 19, 2005 | 01:07 PM
stemyluv69's Avatar
stemyluv69
so i can just push the tensioner from side to side to loosen/tighten? I assume using a prybar to hold the tensioner in place while ratcheting the 14mm bolt is ok to do?
Old Nov 19, 2005 | 03:25 PM
b16ahybrid's Avatar
b16ahybrid
Have you seen the tensioner? It's just a small wheel that has a bolt through it, it spins with the belt. There is a slot in the middle so it can slide back and forth with ease (there is no tension on it so use your hand). When your donr putting the belt on you push it over to put tension on the belt, tighten it and viola your done.
All you need is two hands, one socket wrench and about 22 seconds.
Old Nov 19, 2005 | 05:12 PM
dubcac's Avatar
dubcac
I
The tensioner automatically tensions the belt, so loosening the nut on the tensioner will release tension on the belt. Don't remove the nut completely, just loosen it a bit. When you are done, make sure you torque it to the correct spec, then set belt tension as shown in the how-to.
Old Nov 19, 2005 | 09:29 PM
stemyluv69's Avatar
stemyluv69
you guys be the best Toyota tensioners are a lot different, atleast on the 22r (which is what im use to working on). Anyways, i appreciate it a lot. Should have the cams in after thanks giving, so ill try to get an in car video of the 0-100 soon after.
*street racing references removed by qtiger*
Old Nov 20, 2005 | 07:57 AM
qtiger's Avatar
qtiger
Discussion of or reference to street racing is not allowed on these forums. If your 0-100 video is on public streets I would suggest not posting it unless you want some serious warning points.
Old Nov 20, 2005 | 08:46 AM
sherwood's Avatar
sherwood
I missed Sean
it's all there in quite good detail
