engine sleeves
Old Aug 18, 2005 | 03:19 AM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
Default engine sleeves
What is the process and around how much does it cost to have a 95' b16a1 SiR sleeved? i just ordered my new engine and i'm thing about sleeving it brfore it goes in the car.
-Hobozcar
94' Honda Del Sol
Old Aug 18, 2005 | 06:41 AM
Snoopy's Avatar
Snoopy
been there done that
http://www.honda-tech.com/zerothread?id=565375
this is how benson's does their sleeving. cost will vary from company to company.
Old Aug 18, 2005 | 07:01 PM
b16ahybrid's Avatar
b16ahybrid
I paid $759 for my golden eagle sleeves. They are also on honda-tech.com.
Old Aug 20, 2005 | 07:13 PM
raiden571's Avatar
raiden571
turning u inside out
u really dont need sleeves unless ur pushing over 500. ive seen people with close to 700 on stoc ksleeves. forged internals are amust tho for higher boost applicxations
Old Aug 20, 2005 | 07:47 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
1000 bucks basically if u want it done right, ship it to golden eagle and let them do it.. they give you a gaurantee with it anyway and its right at 1000.
Old Aug 21, 2005 | 07:24 AM
BlueShadow's Avatar
BlueShadow
Even if you dont plan on making lots of power, another advantage of getting your motor sleeved is you can go with a bigger bore size to increase your displacement.
For the original poster I dont know how much it ould be just to sleeve the block, but I recently had my whole block built by Laskey Racing. Earl gets his motors sleeved by Dan Benson himself. I paid $3330 and here is what I got:
$1050 Benson Sleeves install/cylinder hone (you can pick a bore size at no extra cost)
$150 Benson balanced/micropolished crank
$495 CP Pistons and rings
$620 Pauter Rods
$100 ACL bearings
$250 OEM oil/water pump
$50 Gasket/seal set
$490 Blue print and assembly
$125 USA (lower 48) delivery
$3330...Total
If you want it with Pauter rods then it'll be $3430, but that's if he has them in stock. For Eagle rods it's $3050...for my buildup I went with Manley rods, 83mm bore, and an LS crank in my B18C. All that was good for 1925cc's.
