Engine set up?
Old Aug 12, 2005 | 07:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by Paulll
I wouldn't run a block gaurd with a sleeved engine.
He said no such thing about a block guard. A girdle and block guard are two completely different things.
Old Aug 12, 2005 | 08:44 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I had an LS tranny and then went GSR. GSR is much better and the longer gear w/ boost thing is a myth. Getting through the gears faster is the better way to go. Take my word for it.
Old Aug 12, 2005 | 09:54 PM
Zedron's Avatar
Zedron
Turbo B20
well gsr it is then..what are the top speeds for both?
do you think it will run pretty good with a setup like that?
Originally Posted by paull
have fun switching the clutches,
might want to pick up a nice one
changing the clutch isnt the hard part, its getting the tranny out. a clutch chang for me takes 15 minutes from when old one is on to when im ready to put tranny back on.
i mentioned i will be getting a 6 puck racing clutch...egh rough ride.
Old Aug 13, 2005 | 02:08 PM
Paulll's Avatar
Paulll
Hail Bent
sorry, i thought they were the same thing
I'm running the act xtss clutch on my setup, and its rough to ride around in traffic, but well worth it when it comes time to boost. I've heard that 6-pucks are hard on the tranny, which if you have the cash, i would pick something else up.
my car is dd, so i avoided the 6-puck
Old Aug 13, 2005 | 08:23 PM
b16ahybrid's Avatar
b16ahybrid
Correct, you want to go with the lightest clutch that you can get away with.
Example. running a 6-puck w/extreem pressure plate is overkille for a 250hp honda, while a street disk w/hd pressure plate is about perfect..
For your power though your going to need at least a 6-puck w/extreem pressure plate if not a 4-puck disk to hold that power.
You may have to even look into a twin disk.
I know my goal of about 450 (ish) whp and 300+ ft lbs is going to require a 6-puck and extreem pressure plate (ACT)....
I hate to say it for the sake of your wallet but a tildens twin disk may be in order for you if close to 500ft lbs is in your future.
Old Aug 13, 2005 | 08:46 PM
Paulll's Avatar
Paulll
Hail Bent
tilton = balla
Old Aug 14, 2005 | 01:46 AM
Zedron's Avatar
Zedron
Turbo B20
how much are those?
Old Aug 14, 2005 | 08:41 AM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by Zedron
how much are those?
Lots of money......
As the old saying goes, "If you have to ask how much it costs, it's probably to much"
Thats part of the reason why I kept the stock 81mm bore when I had my motor sleeved, I plan to make as much power as my clutch can hold, the next step would be a twin disk. And I don't want to spend that kind of money.....i'll make the best use of the power I'm making.
Old Aug 14, 2005 | 09:42 AM
Zedron's Avatar
Zedron
Turbo B20
heh, i was just wondering how much so i can change my little rough estimate price guide..
Old Aug 14, 2005 | 11:43 AM
Paulll's Avatar
Paulll
Hail Bent
tilton twin disk for a h22 is being sold for 1200 by my friend
