Block Gaurds "Do or Dont"
Old Jul 25, 2005 | 10:01 AM
steven_SA's Avatar
steven_SA
Default Block Gaurds "Do or Dont"
Just wanted to know if anyone has any problems with block gaurds distorting cyclinders. I read somewhere that someone installed a block gaurd and it caused one of his pistons to siezed up at the top of the cyclinderd. Due to the distortion created by the gaurd.
Old Jul 25, 2005 | 11:11 AM
SICK BOY's Avatar
SICK BOY
gsr-t hatch in progress!
if u ever put in a block guard it should be before you hone out the cylinders for new pistons, so the distortion will be corrected. there is no reason to just put in a block guard and not put in new pistons and rods.
Old Jul 25, 2005 | 11:22 AM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
If anyone is going to go through that much work, might as well just get some good closed-deck sleeves.
Old Jul 25, 2005 | 12:42 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:werd:
I couldn't agree more.
Old Jul 25, 2005 | 05:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The distortion isn't created by the guard, but rather the retards that decide to install it by smaking it in with a hammer. It needs to be machined to fit, welded in, the block needs to be redecked, and then the cylinders need to be rebored to correct any out-of-round.
I agree with Westcoaststyle. Screw the work of a block guard and just get it sleeved.
Old Jul 26, 2005 | 04:35 PM
b16ahybrid's Avatar
b16ahybrid
I second (or third) that.
