Let me know Pls?
Old Jun 23, 2005 | 11:08 AM
dohCivic's Avatar
dohCivic
Default Let me know Pls?
i just bought a gsr block with srp forged pistons and rods. now im not sure on the compresstion but i know its low and was used on a turbo setup. the pistons are practically new. the guy totalled the acura and parted it out. he had just got it tuned to. sucks. anyhow i was thinking of ripping the block apart and putting new bearing and rings maybe even balnance everything just to be safe. also can i figure the compression on the pistons. and how much hp can it now handle. it also has a block guard. or should i just go ahead and finish assembling the head and so forth
Old Jun 26, 2005 | 06:53 PM
PHiZ's Avatar
PHiZ
BOOST GOD
You didn't actually ask a question.
-PHiZ
Old Jun 30, 2005 | 06:41 PM
dohCivic's Avatar
dohCivic
how can u tell if a bottom end is in good shape. its outta the car and the head is off. should i replace bearings and all?
Old Jun 30, 2005 | 08:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It wouldn't hurt. Personally, I would rebuild the engine since it is out of the car and you have no idea what was done to it.
Old Jun 30, 2005 | 08:49 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
what shmoo said makes the most sense...:thumbup:
Old Jun 30, 2005 | 09:04 PM
Snoopy's Avatar
Snoopy
been there done that
if you know the specs on the pistons and the cc of your head, you can get a close estimate of what c/r you would have using a compression calculator like www.zealautowerks.com
Old Jul 3, 2005 | 06:28 AM
dohCivic's Avatar
dohCivic
thanks playaz
Old Jul 3, 2005 | 08:01 AM
BoostedITR41's Avatar
BoostedITR41
if you are disassembling it you might as well sleeve the block while it is apart.
Old Jul 3, 2005 | 01:37 PM
dohCivic's Avatar
dohCivic
Yeah i was really considering that. It kinda got me stressin cause it pushes my project back further. If i did ill have a bullet proof motor though so i guess its worth it.
