Question.
Old Jun 11, 2005 | 02:26 AM
psx_pat's Avatar
psx_pat
Default Question.
Does B16a head with B20 block rev up as fast as stock B16a? Cause, B16A head with B20 block is longer stroke. Anyone?
Old Jun 11, 2005 | 07:17 AM
Snoopy's Avatar
Snoopy
been there done that
a stock b20 block wont rev as high as a stock b16
Old Jun 11, 2005 | 07:24 AM
psx_pat's Avatar
psx_pat
Yeah,I understand B20 block won't rev as high as 8K rpm. But I want to know if B20 block will rev up as fast as stock B16a. I mean, for example to reach from 1500rpm to 6500 rpm B20 block will be the same or slower compare to stock B16A? Thanks.
Old Jun 12, 2005 | 04:03 PM
crazy4396063's Avatar
crazy4396063
honda
with the b16's tranny it will....in fact you'll go through the gears a little faster since your redline is 6500-7000
Old Jun 12, 2005 | 04:55 PM
psx_pat's Avatar
psx_pat
Thanks.I heard I need to make the internal stronger in able to go to 8k rpm with B20 block engine. And if I do this, does this B20 block engine make a peak HP on 8k rpm?
Old Jun 13, 2005 | 11:08 AM
b16ahybrid's Avatar
b16ahybrid
The engine is going to rev like a b20 because thats what you have. If your talking about accelerating then thats a different story.
If you want it to rev faster, you can get a lighter flywheel, and ligher internals. But the longer stroke will make it a slower rev.
Peak power will be determined by a lot of factors, the head, compression,performance parts installed all play a role in when and where the power is made.
