How to reset Honda ECU.
Old Jun 6, 2005 | 09:10 AM
psx_pat's Avatar
psx_pat
Default How to reset Honda ECU.
I just want to know, how is the correct way to reset Honda ECU? thanks.
Old Jun 6, 2005 | 09:20 AM
b16ahybrid's Avatar
b16ahybrid
The correct way or a way that works?
I've heard several variations but I always just pull the ecu and back-up fuse for a few then pop it back in. Some say you have to do it when it's cold, I've found That to not be true.
You could always just pull the battery cables for a few also. Either way will clear any codes
Old Jun 6, 2005 | 10:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i just disconnect the battery for about 10 seconds
Old Jun 6, 2005 | 11:25 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Same here. It takes no time at all and you don't need any tools, so it is my favorite way. It does wipe out the preset stations and time, though.
Old Jun 6, 2005 | 12:04 PM
b16ahybrid's Avatar
b16ahybrid
Pulling the two fuses only takes two fingers and it doesn't erase the pre-sets.
the fuses are in the engine bay so no crawling on the ground under the dash
Old Jun 6, 2005 | 02:17 PM
Provocateur
On permanent hiatus
I don't know about you, but I have fat, stubby fingers, so that fuse doesn't come out easily without a pair of pliers.
Old Jun 7, 2005 | 10:19 PM
flatliner's Avatar
flatliner
Fix It
i always thought the haz was KAM ?
Old Jun 8, 2005 | 05:06 AM
b16ahybrid's Avatar
b16ahybrid
Yeah they are kind of a bitch to get out being so close together...
