help me build a "perfect" ls/vtec
Old Jun 4, 2005 | 01:03 PM
BC_BIGBUDZ's Avatar
BC_BIGBUDZ
Default help me build a "perfect" ls/vtec
i have a low km b18b engine sitting in my shop and i have 3k to invest now and another 2k in 4 months
i would like to know what i need to do/buy from beginning to end to build a ls/vtec that will put out around 220 hp
i know this has probably been covered a million times but if any1 takes the time to help me i can pay them sum $$ through paypal
thanks
Old Jun 4, 2005 | 01:46 PM
pomansouth's Avatar
pomansouth
is this a daily driven motor, do you think 5k will get you 220hp?? I am here to tell you, if you want premium, you have to pay premium. You will need to start your build with a b16 head, get it ported and polished by alainaz or someone of the like. you have alot of work to do, and ALOT of money to spend.
Old Jun 4, 2005 | 02:28 PM
BC_BIGBUDZ's Avatar
BC_BIGBUDZ
yes this is for daily
im not sure if 5k will get me 220hp, but im sure even if i can get 190-200 hp i would be very happy
would this be a good head to buy?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
after this what whould would i have to do/buy next
thanks for the help
Old Jun 4, 2005 | 07:27 PM
Snoopy's Avatar
Snoopy
been there done that
85mm bore
89mm stroke
Carrillo Rods
Wiseco +2cc pistons (11.6:1)
RLZ Stage 3 head
RLZ Stage 3 cams
RLZ Single valve springs
JG Intake manifold
Stock ITR TB
Mugen intake
RC 370cc injectors
AN-R header with 3" collector
Thermal 3" exhuast
ATS 4.9 FD
Clutch Masters stage 3 clutch
Toda flywheel
Toda timing belt
Toda cam gears
Drive Shaft Shop stage 3 axles
AEM EMS
the guy with this setup is pushing ~230whp. it will not be cheap.
Old Jun 5, 2005 | 07:32 PM
pomansouth's Avatar
pomansouth
you can go with cheaper brands to make that build a few hundred cheaper, but that build is looking at about 8 grand or maybe a little more.
Dont get that head on ebay, you have the right idea, just need to get a fully assymbled head, its cheaper this way. I know a guy that will get you a GOOD head that is on honda-tech.com, but im not to sure he is still very active on there. Anyhow if you want me to hook you up with him, let me know. He is a little more expensive, but he is definently a trustworthy person. He doesnt sell screwed up heads and so forth. Anyhow let me know if you need to get intouch with him.
Old Jun 7, 2005 | 10:23 PM
flatliner's Avatar
flatliner
Fix It
the ls/vtec is a simple bolt on, the head has the springs needed. i have seen a dozen swap overs, its a bolt up really. 220 whp, i would venture farly to say the bolt up will produce about 150whp. 210 chp/ If you want whp upgrade the rods, use gapless top rings and add a 70 shot with a ported head, it should result in what you desire.
Old Jun 8, 2005 | 04:14 AM
pomansouth's Avatar
pomansouth
but thats not all motor my friend... and ls/vtec is by far not a bolt up idea. I have never seen a bolt on require you take the motor apart and interchange between heads. Where are you getting all of this foul information...
