ctr n1 crank pulley
Old May 28, 2005 | 10:26 PM
Snoopy's Avatar
Snoopy
been there done that
Default ctr n1 crank pulley
anyone have any firsthand experience with one of these? good or bad?
my friend just bought one for his b20vtec project and was wondering what to expect from it.
Old May 29, 2005 | 05:00 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I know Bumnah had one, but I'm not sure if he ever actually installed it.
Old May 29, 2005 | 05:07 PM
Kai's Avatar
Kai
Rotorphile.
HatchVX and I just put one on his car the other day.
Nothing much to say other then to make sure you have the right size belt for it.
Old May 30, 2005 | 08:42 PM
qtiger's Avatar
qtiger
I've got the inlinefour single belt pulley, from back when CTR pulleys weren't available for a few months. As said, make sure you have the right belt or you'll end up with some annoying squeal in cold and wet.
What belt did you end up running Kai?
Old May 30, 2005 | 09:43 PM
Civic2Scooby's Avatar
Civic2Scooby
what belt did you run? I bought one like 2 years ago but never put it on...I am selling my B swap and my roommate wants my CTR crank pulley.
Old May 31, 2005 | 09:11 AM
Snoopy's Avatar
Snoopy
what im really concerned is with the stories of the pulley shortening the lifespan of the engine because it's not balanced and has no harmonics dampening. this is going onto a stock internals b20b block that will be rebuilt with new rings, gaskets, etc.
Old May 31, 2005 | 01:12 PM
qtiger's Avatar
qtiger
If you're really worried about it you could get one of the IL4 pullies, they are an OEM pulley w/ rubber insert that's had the other two belts milled off.
Ding: http://www.inlinefour.com/infourn1encr.html
I wouldn't be too concerned about an OEM Honda part like the N1 pulley.
Old May 31, 2005 | 04:23 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
the autozone part number is 4PK735. I haven't noticed any difference yet, maybe when i get a lighten flywheel it will help out.
Old May 31, 2005 | 04:24 PM
Kai's Avatar
Kai
Rotorphile.
I think it was a 230mm... HatchVX had to special order it from the Advance Auto down the street when we figured out the stocker didn't fit and our parts department didn't have anything small enough.
Old May 31, 2005 | 04:54 PM
qtiger's Avatar
qtiger
Hmm, I wonder if the diameter of the CTR pulley is the same as that IL4 pulley I got... I think I just ended up getting one size smaller than my stocker.
