best mod for torque?
Old May 15, 2005 | 10:17 AM
crazy4396063's Avatar
crazy4396063
honda
Default best mod for torque?
i have a jdm b16a what would my best mod for torque be? should i do the cr vtec frankie swap? or keep the engine and go turbo? or what would be the best bolt ons?
Old May 15, 2005 | 10:34 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Turbo it. That will give you a good grip of torque.
Old May 15, 2005 | 10:39 AM
crazy4396063
honda
what is a safe psi for stock internals? and what is the best turbo for this engine....i have a garrett t3 sitting in my room but i think it might be to small....but i could just get a small exhaust turbine so it spools up more slowly right?
Old May 15, 2005 | 12:07 PM
ED9man's Avatar
ED9man
driver
V8 :chuckles:
Basically anything you bolt on will give you less low end torque.
Old May 15, 2005 | 01:15 PM
b16ahybrid's Avatar
b16ahybrid
About 300whp is safe for that motor.
What are the specs of that turbo? Trim, A/R etc. Smaller exhaust would equal faster spool, larger exhaust turbin slower spool.
Old May 15, 2005 | 01:16 PM
Provocateur
On permanent hiatus
Originally Posted by ED9man
V8 :chuckles:
Except a supercharger. But those suck anyway.
You don't need much low end torque because in a race, you will spend 99% of the time in the upper RPM powerband.
Old May 15, 2005 | 02:05 PM
pomansouth's Avatar
pomansouth
superchargers arent as bad as you might think. Dont listen to everything on the net and by word of mouth. Know the people that you are listening to, i know a guy shooting for 10 sec pases on the quarter with a supercharger on just 10 pounds, show me how many turbos push ten pounds is ten seconds down the quarter. Dont knock it before you try it. Anyhow, there is nothing wrong with turbo or superchargers and nothing wrong with all motor or nitrous, just do your homework before you try anything stupid.
Old May 15, 2005 | 03:15 PM
crazy4396063
honda
how come my buddy can run high 13's low 14's with a stock b20b in a crx the torque and hp specs are around 126 technically the hp of my engine is way more powerful and he has about 10-15 more ft.lbs torque......and his car is 1800 lbs and mine is 2300 ....and im only running mid 14's (stock). does this sound right to you guys? .......btw the A/R on my t3 i believe is .48...i do not know the trim....but is there a way i can reduce the compressor wheel for a slower spool? or would i need a bigger turbo?
Old May 15, 2005 | 03:50 PM
Snoopy's Avatar
Snoopy
been there done that
power to weight ratio
Old May 15, 2005 | 04:19 PM
crazy4396063
honda
tru i notice a big difference with my girlfriend in my car and she only weighs a 100pounds!
