best mod for torque?
Old May 15, 2005 | 04:28 PM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by crazy4396063
how come my buddy can run high 13's low 14's with a stock b20b in a crx the torque and hp specs are around 126 technically the hp of my engine is way more powerful and he has about 10-15 more ft.lbs torque......and his car is 1800 lbs and mine is 2300 ....and im only running mid 14's (stock). does this sound right to you guys? .......btw the A/R on my t3 i believe is .48...i do not know the trim....but is there a way i can reduce the compressor wheel for a slower spool? or would i need a bigger turbo?
The exhaust is .48 and the compressor is .42? If so I wouldn't recomend that turbo for your engine, I ran that turbo on mine for a while...it sucked
Smaller turbo = faster spool so going with a smaller compressor would result in faster spool and less top-end power.
Old May 15, 2005 | 04:51 PM
crazy4396063's Avatar
crazy4396063
honda
what turbo are you running +how much did it cost for your setup. is there anyway i can change the wheel to a bigger one and have it spool up slower so i can get all my top end power with this turbo?
Old May 15, 2005 | 05:02 PM
b16ahybrid's Avatar
b16ahybrid
I'm running a garrett t3t40E .57 trim .63 a/r. I have about $3,000 into my set-up but that includes tuning.
I made 199whp @10psi with that t3 listed prior, I swapped to my current t3t4 and dyno'd at 226whp without changing anything else. Then I switched to hondata and made 248whp @9psi....I'm sure I could have gotten more out of that with a little better tuning.
Old May 15, 2005 | 05:18 PM
crazy4396063
honda
do you have stock internals too?
Old May 15, 2005 | 08:36 PM
b16ahybrid's Avatar
b16ahybrid
Yes I did.
Old May 18, 2005 | 01:47 PM
crazy4396063
honda
is there anyway i can mod this turbo to get a slower spool?
Old May 21, 2005 | 07:36 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Nitrous
