check valves
Old May 13, 2005 | 02:47 PM
civicblue4's Avatar
civicblue4
Default check valves
Hi have bought 3 aquarium check valves for temp use...I need some help i have install 1 check valave on the vaccum line running from the map sensor to the throttle the bogges down and die,i'm using a check valve that has a ball and spring is there something i'm doing wrong thanks.
