SRS Light stays on
Old Apr 25, 2005 | 07:26 AM
96accordlx's Avatar
96accordlx
Default SRS Light stays on
I have a 96 Accord LX that all of the sudden the SRS light has come on and does not go off. Is this a common problem in these cars and is there anything I can do to check it or do I need to bring it to a dealer?
Old Apr 25, 2005 | 05:06 PM
EH339's Avatar
EH339
Since you have an OBD2 car, go to a place like Autozone and they will pull your problem code for free.
Old May 7, 2005 | 05:42 PM
georgie's Avatar
georgie
the local shops i went to such as autozone said their scan tool does nto do airbag lights only engine lights.
Mine is on also
Old May 7, 2005 | 07:23 PM
EH339's Avatar
EH339
Well, I don't have an Accord Helms.... but in the 98 Integra Helms, the first suggestion is to check the underdash fusebox for the SRS system fuse (for an Integra it's the No. 23 (10A) fuse). If it's blown, replace. Then you need to erase that DTC memory. Disconnecting your battery for a few minutes may accomplish that, but I'm not sure. All my cars are OBD1.
Then if not the fuse, the other troubleshooting suggestions are checking for opens and shorts in the SRS wiring, but you really DON'T want to mess with that. You don't want to trigger your airbags by accident. That would be both dangerous and expensive for you... so it's well worth going to the dealership to have that checked out.
Old May 8, 2005 | 01:32 PM
mikemerc85's Avatar
mikemerc85
Git-R-Done
dont do anything else but go straight to the dealer and tell them ur problem. You dont wanna mess with the SRS. Could be just as simple as a bad sensor in which they'll throw on a diagnostic computer and find the error code.
Old May 8, 2005 | 01:45 PM
EH339's Avatar
EH339
^^^ A fuse is very safe to check for. The rest I agree with.
Old May 10, 2005 | 09:54 PM
Luda Si's Avatar
Luda Si
i think your air bags dont work dude!
Old Jun 3, 2005 | 09:29 AM
95civiclx's Avatar
95civiclx
HMT b7
check on your drivers side door jam when the srs was installed. mine went off 10 years after installation.....which is when you are supposed to have it inspected...i think that might have something to do with it
Old Jun 3, 2005 | 02:36 PM
KriS1's Avatar
KriS1
Take to the dealer. My 94 civic had this at one point, I took it to the dealer and they fixed it free of charge
Old Jun 3, 2005 | 06:34 PM
flatliner's Avatar
flatliner
Fix It
05 civiclx, i aggree.
