B20 Swap
Old Apr 19, 2005 | 03:38 AM
Ziken's Avatar
Ziken
RACE USE ONLY
Default B20 Swap
I was wondering what I will need for a b20 swap. Im planning to do the vtec head on it. What tranny do i use with it? BTW I have a 97 hatch
Old Apr 19, 2005 | 03:39 AM
Ziken's Avatar
Ziken
RACE USE ONLY
Oh, and is there a difference on the weight between the b20 and a b18?
Old Apr 19, 2005 | 04:34 AM
gingas's Avatar
gingas
I do believe the B20 is heavier. Why dont you go with a B18C1 & do some work for all motor. If thats the case I'd go with the H22 IMO.
Old Apr 19, 2005 | 08:54 AM
Youlll need integra axles, ARP head studs, might get some rod bolts too, And of course your OBD2 stuff, dizzy, injectors, etc.... some more stuff to it, but i cant remember, i just helped with this swap 3 days ago too into an EG. *everyone else should be able to give you more, i cant remember anything this early in the morning*
Oh yeah you can use any B series trans
Old Apr 19, 2005 | 11:17 AM
Ziken's Avatar
Ziken
RACE USE ONLY
What ecu do i need to use?
Old Apr 19, 2005 | 11:19 AM
Snoopy's Avatar
Snoopy
been there done that
an obd2 p75 if you plan to keep it non vtec
Old Apr 20, 2005 | 11:32 AM
Ziken's Avatar
Ziken
RACE USE ONLY
what if i plan on doing a vtec head later?
Old Apr 20, 2005 | 11:36 AM
Snoopy's Avatar
Snoopy
until you get the vtec head, use the p75. when you do get the head, you can use a chipped p28 or p30 and something to tune with. p28's are easier to find though.
Old Apr 25, 2005 | 02:29 PM
Ziken's Avatar
Ziken
RACE USE ONLY
What is a good tranny for the swap? I want something that has acceleration but at the same time has some top end speed
Old Apr 25, 2005 | 02:41 PM
If you know your going ALL motor B16 trans with LSD... FI either GSR or LS.... Id prefer the GSR because it does a bit of go compared to the LS
BTW LSD on all of the trans
