97 accord check engine light code help
Old Apr 2, 2005 | 10:21 AM
zell1985's Avatar
zell1985
Default 97 accord check engine light code help
My check engine light came on and i got the codes
i know from the forums that
P0304 - piston 4 misfire
P0303 - piston 3 misfire
but the third code i have not seen anywhere is
P01259
any help here please?
Thankds
zell1985
Old Apr 18, 2005 | 02:41 PM
dukwei's Avatar
dukwei
how do you check the codes? is that where you use a paper clip in stick it in the harness(es) located under the glove box? i would like to know how to do it in case i run into this problem w/ my 97 accord. if so, how do i decipher the codes? how do you know the codes are P0304? sorry, i'm a newbie. any help would be greatly appreciated. thanks!
Old Apr 19, 2005 | 05:06 AM
JimBlake's Avatar
JimBlake
P1259 is a VTEC system malfunction.
- Make sure you're not low on oil.
- Check wiring for your VTEC oil pressure switch & VTEC solenoid.
dukwei...
The codes you get by jumpering the SCS connector are simple 2-digit codes. When you plug in an OBD-2 code reader (like AutoXone does) you get these codes. P1257, P1258, & P1259 would be code 22 if you used the jumper/flashing-light method.
