gsr pistons in ls/vtec
Old Mar 19, 2005 | 04:32 PM
sp00nfKeD's Avatar
sp00nfKeD
Default gsr pistons in ls/vtec
i was wondering if i would be able to use gsr pistons in a ls/vtec build,and is it a good/bad thing?if good could u tell me why and for bad also, i will be using a gsr head on the build,can someone help me out with some info, ive searched but no luck on it.
Old Mar 20, 2005 | 08:15 AM
qtiger's Avatar
qtiger
Yes, but frankly they don't have the compression to make power. If you want OEM pistons, I'd use the USDM or JDM Type R pistons.
Old Mar 20, 2005 | 03:50 PM
sp00nfKeD's Avatar
sp00nfKeD
i thought gsr compression ratio was 10:1 and the jdm gsr which i have is 10:6
Old Mar 20, 2005 | 04:28 PM
Snoopy's Avatar
Snoopy
been there done that
use this compression calculator to figure out where you'd be if you used those pistons.
www.zealautowerks.com
Old Mar 20, 2005 | 05:15 PM
sp00nfKeD's Avatar
sp00nfKeD
thanks alot, this sure does help
Old Mar 20, 2005 | 07:27 PM
Illegal B16's Avatar
Illegal B16
New Zealand
I was under the impression that the deck height with a LS VTEC would be to short for a Ls crank rods and gsr pistons. Your best bet is to use B16a2 pistons or ctr pistons. The b16a2 (00 Si) will net you 11.3-11.5, with a ls crank and rods, the numbers go to 11.5-11.7 due to the better throw.
Old Mar 22, 2005 | 06:19 PM
sp00nfKeD's Avatar
sp00nfKeD
ill be using type r pistons now, i think my compression should be around 11:0-11:5, piston to deck height should be around 0.030in
Old Sep 30, 2008 | 09:44 PM
95eglsvtec's Avatar
95eglsvtec
can you run ls rods on type r pistons??? on a ls/vtec setup
thanx
