Accord engine swap
Old Feb 17, 2005 | 08:24 PM
themanosteel's Avatar
themanosteel
Default Accord engine swap
I have a 91 accord with a f22 sohc engine with a manual transmission. I bought a JDM 94 honda accord wagon ce1 F22B sohc VTEC engine with an automatic tranny. I want to swap engines only. An engine swap book I have says this is a simple direct bolt up job. All I have to do is use the JDM engine computer. My mechanic says he thought the engine to transmission bolt pattern is different amd the swap may not work. Can anybody help us with some answers.
Confused novice.
Old Feb 17, 2005 | 09:14 PM
sherwood's Avatar
sherwood
I missed Sean
Confused novice.
should bolt right in....
i would have bought a h22 tho :-/ eh
Old Feb 18, 2005 | 09:30 AM
themanosteel
Thanks for the reply. I wanted a H22 but the pocket book wouldn't stand it. Oh well the VTECH will give me a little more power and a little more response. Is that correct or am I dreaming?
Old Feb 20, 2005 | 08:38 AM
sherwood's Avatar
sherwood
I missed Sean
Thanks for the reply. I wanted a H22 but the pocket book wouldn't stand it. Oh well the VTEC will give me a little more power and a little more response. Is that correct or am I dreaming?
vtec* it's not a word, its an acronym
the rule is DOHC VTEC>(SOHC VTEC = DOHC)>SOHC in my book...
go test drive a f22b1 accord.... and see the difference before you even try it
Old Feb 21, 2005 | 01:11 PM
themanosteel
K.... the engine in the 91 is a f22b1 non vtec sohc anyway that's what I thought it was. Maybe I just don't understand. Like I said at the start I don't have much experiance in this stuff. And I need lots'a help.
I have some questions about the ecu, my mechanic doesnt think that the japanese ecu will match the u.s. wiring. can anyone help me there?
Old Feb 21, 2005 | 02:24 PM
b16ahybrid's Avatar
b16ahybrid
The ecu's should use the same plugs.
The only difference my be the tune of the ecu...possibly more agressive then the usdm ecu since they have higher octane fuel.
Old Feb 21, 2005 | 03:54 PM
chewacka's Avatar
chewacka
Barquisimeto Type-S
The troubles that u will have are the o2 sensors, and by my experience u will have problems with the wiring set on the distributor plugs and of course the missing plug for the vtec solenoid, but if u have the jdm wiring set your swap, on my shop, it's done, so enjoy the Vtec power........
Old Feb 21, 2005 | 06:31 PM
themanosteel
Cool! thanks a lot! :bigok:
Old Feb 21, 2005 | 06:36 PM
themanosteel
Yeah... I got the jdm wiring set kinda. It was just lopped off at the firewall.
It will make the job a lot easier if I can get a complete wiring set is that right?
Old Feb 22, 2005 | 03:25 AM
chewacka's Avatar
chewacka
Barquisimeto Type-S
Yes if you can find the wiring set will be easy..... check e-bay cause i saw it many weeks ago.........
