help!!!! oil in exhaust
Old Jan 1, 2005 | 03:07 PM
shawn_crx8891's Avatar
shawn_crx8891
yeah, i actually had the compression results in another thread that i think you had replied to. they were 220, 211, 216, 205 the first time, and the second time yielded a 196 on the cylinder that had 220 the first time. the engine seems to run fine other than the smoking. i had suspected that the headgasket may be bad because there is an external leak of oil and coolant, but i can't pinpoint where exactly it's coming from. it really looks to be coming from between the head and block, though. the smoke is definitely white, but i can't decide whether it's oil or coolant. it smells very slightly sweet, and it doesn't really smell like oil.
Old Jan 1, 2005 | 03:11 PM
If it smells sweet its a head gasket. I had the same problem with my car and it turned out to be a cracked head a blown headgasket. Id check those and see what happens. But the beater would sound good right about now
Old Jan 1, 2005 | 03:36 PM
shawn_crx8891
did you have the problem with oily water in your pcv system?
Old Jan 1, 2005 | 03:39 PM
BoostedITR41's Avatar
BoostedITR41
don't drive it if you suspect the head gasket or you may warp the head.....get a HG from honda and see if it fixes it
Old Jan 1, 2005 | 06:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Oh, ok. I remember now. I hate to tell you but it just might be a blown headgasket causing these problems. It is expensive or time consuming but it is the first step I would take. It sounds to me like the leak between the head and block and the white smoke is a headgasket gone bad.
Old Jan 1, 2005 | 11:25 PM
shawn_crx8891
yeah, it looks like i'm going to start looking for a new turbo and get a headgasket, timing belt, and water pump and do everything at once. thanks for the input.
