tranny acting weird...
Old Aug 19, 2002 | 10:11 AM
93acuraviga's Avatar
93acuraviga
Default tranny acting weird...
I've got a 93 acura vigor and lately it has been shifting differently. It doesnt exactly slip but it just shifts from 1st to 2nd and back to 1st at odd times. And when im in 4th, it seems like it wont go past 5000 rpms (redline at 6800). I changed my tran fluid and that didnt seem to help any... should i maybe start looking at a rebuild or might it be something else like i just need to adjust the valves?? im kinda clueless right now so any help will be nice- thanks
Old Aug 19, 2002 | 01:32 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: tranny acting weird...
It's probably engine-related. A friend of mine recently was having the same shifting problems in his 93 Buick, and it turned out that the engine needed quite a bit of tune-up work, including two new transformers for the distributor-less ignition system.
If you haven't done a tune-up recently, replace all the usual stuff...spark plugs, plug wires, cap/rotor (or related spark timing components, depending on what your car has), and possibly the air filter. Also, check the timing with a timing light, that could also be causing power loss if it's off.
Old Aug 19, 2002 | 09:21 PM
93acuraviga
Alright thanks for the help, i'm probably about due for a tuneup anyways.. by the way would the o2 sensor have anything to do with it maybe?? just a thought because the person i bought the car from i remember said somethin about needing to check the sensor..?
Old Aug 20, 2002 | 09:09 AM
AwwsChwA's Avatar
AwwsChwA
the o2 sensor can affect performance, but usually not enough to mess with the engine's shift points. But if it's going bad, it's a good idea to replace that too along with your tune up
georgelv1999
CRX & Pre 92 Civic
3
Jul 3, 2006 12:57 PM
92+ Civic/EL & Del Sol
6
Apr 8, 2004 05:01 PM
accordman
Accord
3
Dec 12, 2003 09:09 AM
jem7vwh
Accord
6
Nov 4, 2003 11:25 AM
