1994 Accord LX acting weird... noise, throttle...
Old Nov 3, 2003 | 02:48 PM
jem7vwh's Avatar
jem7vwh
Default 1994 Accord LX acting weird... noise, throttle...
I noticed my 94 LX 4 cylinder seems quite a bit *louder* from about 25mph up to 60. This is weird because I don't have any mods done at all. It's a stock Accord muffler and exhaust.
Also, when I was driving today it took a lot of effort to get the engine to increase in speed from 60 to 65. It was like the transmission didn't want to shift.
So the question is, what could be causing more engine noise that's directly proportionate to throttle (ie... very quiet at idle, but loud above about 20mph) and a slow throttle response? Thanks...
Old Nov 3, 2003 | 03:32 PM
pirate252's Avatar
pirate252
doesnt it get louder, then quieter (shifting)...what your describing is that its a constand loud noise past 25 to 60...it should make noise if you are pressing on the gas hard and the only way the 60-65 thing makes sence is that you wernt pressing on the gas enough to make the car want to downshift...be a little more descriptive or somthing then maybe someone can figure it out
Old Nov 3, 2003 | 08:20 PM
jem7vwh's Avatar
jem7vwh
I understand that the rpms and noise naturally increase as you excellerate through each gear change, but what I'm saying is that the *whole* experience is louder. When I press the gas, it's a noticeable rumble, which is not normal for my car. Even as the rpms drop after the shift is completed, it's still louder than usual.
Old Nov 4, 2003 | 07:06 AM
pirate252's Avatar
pirate252
so 3k going 55 is louder than 3k at 25?
Old Nov 4, 2003 | 08:57 AM
jem7vwh's Avatar
jem7vwh
No, 3k at 25 mph is louder than 3k at 25 mph two weeks ago. I'm saying that the engine is just louder in general (except at idle)
Old Nov 4, 2003 | 10:42 AM
Camride's Avatar
Camride
Check your exhaust for leaks(holes). I have seen plenty of rusted through resonators and mufflers, might be a good thing to check out. As for the power loss, not sure. If there is a hole in the exhaust close to the O2 sensor or something it could cause problems... Other than that I'm not sure...
Old Nov 4, 2003 | 11:25 AM
uclaccord's Avatar
uclaccord
popped a hole in the exhaust piping somewhere?...makes it louder and weaker
