vtec not working
Old Oct 29, 2004 | 02:33 PM
bboy21385's Avatar
bboy21385
Default vtec not working
ok i finnally got my clutch hook up. I got a 92 civic cx HB with a b18c1 in it. 11:5:1 compression, skunk2 intake manafold cam gear and cam shafts. aem fuel rail and pressure regulator. titanium valvle springs and retainers and a skunk2 ecu. I drove it for the first time today but was quick but i dont think the vtec kicked in how can you tell if it works? and my speedometer doesnt work and i dont know how to get the tach to work. i hooked the motor up my self and the most i did before was change a altonator or starter. so i still have a alot to learn. if anyone could help me out it would be greatly appreciated. thanks
Old Oct 29, 2004 | 04:08 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
well, did you rev it high enough to kick vtec in?
Old Oct 29, 2004 | 04:10 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
If the speed sensor isnt working vtec will not work. What codes are you throwing? Certain codes will put the motor in safe mode=no vtec.
Old Oct 29, 2004 | 04:15 PM
bboy21385's Avatar
bboy21385
Default k
yeah i reved it pretty high but i dont have a tach working or the speedometer. you know how you hook either of them up. i dont know if i am throwing codes how do i find out.
Old Oct 29, 2004 | 04:21 PM
bboy21385's Avatar
bboy21385
Default k
Old Oct 29, 2004 | 10:30 PM
dubcac's Avatar
dubcac
I
Take it to someone who knows what they're doing, and save yourself the troubles.
Old Oct 30, 2004 | 02:02 PM
Snoopy's Avatar
Snoopy
been there done that
:werd: before you mess it up more
Old Nov 2, 2004 | 05:19 AM
xfactor's Avatar
xfactor
In order for the ECU to initiate the VTEC system, 5 engine conditions must be met:
Temperature: The engine must have reached normal operating temperature.
Throttle Position: The throttle must be open far enough to allow for increased airflow in VTEC.
Vehicle Speed: The car must be in motion (wheels spinning).
RPM: Engine must spin to its target value. A GS-R for example starts at 4400 RPM’s.
Oil Pressure: The engine must be operating with normal and safe levels of oil pressure determined by the VTEC pressure switch.
Old Nov 2, 2004 | 06:44 AM
b18coupe's Avatar
b18coupe
what pistons, just wondering.
Old Nov 2, 2004 | 10:52 AM
bboy21385's Avatar
bboy21385
Default How Can I Hook Up The Speedo?
i got the tach to work i connected it to the blue wire on the wiring harness on the distributer.
